Configure IGMP for each interface to enable the interface to perform multicasting operations.
IGMP Field Descriptions
Use the data in the following table to use the IGMP tab.
Name |
Description |
QueryInterval |
Configures the frequency (in seconds) at which the interface transmits IGMP host query packets. The range is from 1–65535 and the default is 125. |
QueryMaxResponseTime |
Configures the maximum response time (in tenths of a second) advertised in IGMPv2 general queries on this interface. You cannot configure this value for IGMPv1. Smaller values allow a router to prune groups faster. The range is from 0–255 and the default is 100 tenths of a second (equal to 10 seconds). Important:
You must configure this value lower than the QueryInterval. |
Robustness |
Configure this parameter to tune for the expected packet loss of a network. This value is equal to the number of expected query packet losses for each serial query interval, plus 1. If you expect the network to lose query packets, increase the robustness value. The range is from 2–255 and the default is 2. The default value of 2 means that the switch drops one query for each query interval without the querier aging out. |
LastMembQueryIntvl |
Configures the maximum response time (in 1/10 seconds) inserted into group-specific queries sent in response to leave group messages. This value is also the time between group-specific query messages. You cannot configure this value for IGMPv1. Decrease the value to reduce the time to detect the loss of the last member of a group. The range is from 0–255 and the default is 10 tenths of a second. Configure this parameter to values greater than 3. If you do not require a fast leave process, Use values greater than 10. (The value 3 is equal to 0.3 seconds and 10 is equal to 1 second.) |
SnoopEnable |
Enables snoop on the interface. The default is disabled. |
SsmSnoopEnable |
Enables SSM snoop. The default is disabled. |
ProxySnoopEnable |
Enables proxy snoop on the interface. The default is disabled. |
Version |
Configures the version of IGMP (1, 2 or 3) that you want to use on this interface. For IGMP to function correctly, all routers on a LAN must use the same version. The default is version 2. |
FastLeaveEnable |
Enables fast leave on the interface. |
StreamLimitEnable |
Enables or disables stream limitation on this port. |
Maximum Number Of Stream |
Configures the maximum number of streams this port permits. The range is from 0–65535 and the default is 4. |
Current Number Of Stream |
Displays the current number of streams. This variable is a read-only value. |
FastLeavePortMembers |
Lists ports that are enabled for fast leave. |
SnoopMRouterPorts |
Shows the configuration of ports as multicast router ports. Such
ports attach to a multicast router, and forward multicast data
and group reports to the router.
Important:
Configure this variable only if you use multiple multicast routers that do not attach to one another, but attach to the VLAN (technically, an invalid configuration). If multicast routers use a route between them (the valid configuration) and you configure this variable, a multicast loop forms. |
RouterAlertEnable |
Instructs the router to ignore IGMP packets that do not contain the router alert IP option. If you disable this variable (default configuration), the router processes IGMP packets regardless of the status of the router alert IP option. To maximize network performance, configure this parameter according to the version of IGMP currently in use:
DynamicDowngradeEnable |
Configures if the switch downgrades the version of IGMP to handle older query messages. If the switch downgrades, the host with IGMPv3 only capability does not work. If you do not configure the switch to downgrade the version of IGMP, the switch logs a warning. The default value is selected (enabled), which means the switch downgrades to the oldest version of IGMP on the network. |
CompatibilityModeEnable |
Enables or disables v2-v3 compatibility mode. The default value is clear (disabled), which means IGMPv3 is not compatible with IGMPv2. |
ExplicitHostTrackingEnable |
Enables or disables IGMPv3 to track hosts per channel or group. The default is disabled. You must select this field if you want to use fast leave for IGMPv3. |
